App x Android: AirControl Mobile e EasyUbnt 5.5
Re: App x Android: AirControl Mobile e EasyUbnt 5.5
Messaggiodi ispsoft_1 » 23 giugno 2014, 21:21
Few days ago I released a new Android app for UBNT MPower devices. It can setup new devices, remotely check their states, power consumption and switch on/off the sockets. It's now in beta and totally free. It would mean a lot to me if you try that and send me some feedback.
You can find it here on Google Play:
https://play.google.com/store/apps/details?id=com.ubnt.mpower
Some screenshots here:
Main Screen
Adoption Screen
Main Screen 2
ispsoft_1
Messaggiodi ispsoft_1 » 8 luglio 2014, 19:58
The new version 6.2 is available on Google Play.
Here is the list of changes:
  • New feature – Added support for getting GPS coordinates from android device in Configurator
  • New feature – Added frequency scan list in Configurator
  • New feature – Added sound on/off switch to Airfiber status
  • Fixed – Text-To-Speech fixed on Android 4.X
  • Fixed – Various minor bugs reported by users
Link to Google Play: https://play.google.com/store/apps/details?id=com.ispsoft.easyubntfull55
GPS Location
ispsoft_1
Messaggiodi ispsoft_1 » 22 settembre 2014, 19:33
The new version 6.3 is available on Google Play.
  • Fixed - Fixed crashing on Nanobeam M400
  • Fixed - Fixed problem with antenna selection on Nanobeam M400
  • Fixed - Fixed device list conversion from older EasyUbnt versions
ispsoft_1
Messaggiodi ispsoft_1 » 11 novembre 2014, 19:43
New version 6.4 has been just released!
Version 6.4
* New feature - Translation to Italian
* New feature - Added support for screen rotation
* New feature - Added WLAN IP and LAN IP to Status window for AirOS 5.5 and higher
* New feature - Added filter text field to Site Survey
* New feature - Added export button to Status window
* New feature - Added Italian language
* Fixed - Data speed on AirFiber firmware 2.0+
* Fixed - Scan list text field expanded to contain more frequencies
* Fixed - Distance for AirFiber now in km and miles
ispsoft_1
Messaggiodi Mrmamo1259 » 12 novembre 2014, 10:39
Riparto da qui.
Come si fa ad accedere all'NVR e quindi alle cam tramite un cellulare?
Chi conosce e saprebbe spiegare in parole povere, cme avessi 6 anni, tutta la procedura da fare per settare modem/ruoter, Nvr, telefono android/mac ecc..... :S :eheh:
ho letto che si deve nattare qualcosa? :oo: insomma, una guida completa mi servirebbe!!! :fifi:
Mrmamo1259
Messaggiodi thema3x » 12 novembre 2014, 11:46
:zip: :eheh:
Messaggiodi ispsoft_1 » 24 marzo 2015, 0:32
New version has been just released!
Changelog:
* New feature - Added Spanish, Russian and Turkish
* New feature - Added support for PowerBeam devices
ispsoft_1
Messaggiodi nivomat » 9 novembre 2015, 23:03
C'è qualcuno che ha provato l'app "UniFi AC EasySetup" per i nuovi UAP-AC?
Io ho provato a ricercare il mio UAP-AC-LR ma dopo aver inserito il MAC oppure il QR code rimane a macinare per ore sulla stessa schermata dicendo:
"Connecting to helper SSID - Connected. Waiting for response..."
Da cosa può dipendere?
nivomat
Messaggiodi thema3x » 10 novembre 2015, 9:30
onestamente io non ne ho idea, sarebbe da chiedere a chi ha scritto l' app, magari con una mail. :eheh: cosi poi posti la risposta :love1:
Messaggiodi nivomat » 11 novembre 2015, 23:45
Detto fatto! Ora sono in contatto con un certo Vladimir :D
Speriamo di risolvere.
Ho notato che sopra la stampa del MAC e del QR Code ci sono state incollate delle nuove etichette per aggiornare queste due informazioni. Lo UAP-AC-LR l'ho comprato nuovo da un sito italiano.
E' normale?
nivomat
