AirOS 5.2 - Firmware Officially Released!!!
Messaggiodi admin » 17 maggio 2010, 9:16
Rilasciato AirOS 5.2!
Version 5.2 - Final Release (May 14, 2010)
- New: Speed test tool
- New: AirView tool (Spectrum Analyzer mode)
- New: Routing scenario: Network mode "Soho Router"
- New: NanoStation M5/M2 Second Ethernet port functionality -- now it is possible to bridge with wireless port
- New: Antenna gain and cable loss fields for compliance
- New: AirMax ON in default configuration
- New: Intelligent GUI improvement
- New: Console agent: Restore active heartbeat connections after firmware upgrade
- New: Report 802.11 information messages into syslog
- New: Improve ACL rules management: increase max MAC ACL entry count to 32
- New: Remove DFS 5250-5350 frequency for US country code (all M series products)
Improvements/Change requests:
- CCR: RADIUS client support in AP mode
- CCR: PEAP/MSCHAPv2 support
- CCR: Add static routes via WEB UI
- CCR: Show Station and AP IP address
- CCR: Hide WPA password with "*"
- CCR: Ability to de-associate station from Station list via WEB UI
- CCR: Add support for SSH authorized keys in configuration file
- CCR: Change apply configuration logic
- CCR: Missing ppp0 interface information on Main page, when PPPoE session is initialized
- CCR: Add System Startup Time/Date field (critical for 802.1x supplicant)
- CCR: Allow ping when device is in TFTP recovery mode
- CCR: Include PPTP/GRE NAT modules
- CCR: Add MAC clone/change option for WAN interface when operating in SOHO router mode
- CCR: Report AirMax priority and AMQ/AMC in Station detail
- CCR: Speed test: Show total throughput (RX + TX)
- CCR: Make IP address in stations list as hyperlink
- CCR: GUI: Show/hide Traffic shaping configuration
- CCR: GUI: Add option to enable/disable NAT modules on router: SIP, PPTP, FTP, RTSP
- Improvement: Speed test: resolves TX/RX difference
- Improvement: In memory allocation
Fixes:
- Fix: TX Power improvement for NanoBridge M5, AirGrid M5, NanoStation Loco M5, Bullet M2, Rocket M2, NanoStation M2, NanoBridge M2
- Fix: Chain signal mismatch on reported signal strength/ Power control for M5 2x2 chain devices
- Fix: Sometimes Auto ACK values gets too high
- Fix: Max power level for Australia
- Fix: Speed test + AirMax PtP No Ack combination crashes AP
- Fix: Traffic Shaping is not functional except Soho Router mode
- Fix: Traffic Shaping Burst is for functional
- Fix: WPA security : Sometimes station is disassociated from AP
- Fix: Broadcast traffic is duplicated on AP-WDS
- Fix: NAT protocols state changes when changing security
- Fix: SNMP wrong OID type: Disallow port range as destination (to private subnet)
- Fix: SNMP reports incorrect wireless stats
- Fix: Station can not connect to AP (MAC Locked) if it was connected to another AP with the same SSID
- Fix: Signal reporting
- Fix: Improve noise level calculation
- Fix: Noise floor is too aggressive
- Fix: Auto ACK on AP
- Fix: No more trimmed channels on Compliance country code
- Fix: Airmax: PTMP ping loss issue after beta6
- Fix: AirMax: PTPNack AMQ/AMC fluctuation
- Fix: AirMax: PTP and PTMP enhancements (latency)\
- Fix: Airview: Sometimes switching back to normal operating mode is endless
- GUI fix: Problems with WPA PSK paraphrase: old value is displayed, new value is not saved
- GUI fix: Sometime Device name in not reported in Stations list
- GUI fix: Do not show clients as connected when authentication key is not valid
- GUI fix: Test mode. Timing is no so precise as stated in the warning message
- GUI fix: Need correctly display ACK/Distance when AirMax and PtPNoACK mode is enabled
- GUI fix: Name -> Device Name
- GUI fix: Grammar error in warning message
- GUI fix: MCS1 is always reported in AP/Station statistics
- Fix: IE8 and WEB UI errors
- Fix: Frequency list issue fix for counties:
Uzbekistan
Brazil
Honduras
Peru
Philippines
Russia
South Africa
Sri Lanka
Thailand
Known issue:
- Limitation from HW: MCS13 does not work with WEP/WPA/WPA2/WPA-TKIP/WPA2-TKIP security -- MCS 13 removed from WEB UI
Disponibile alla pagina di download ufficiale.
Buon divertimento! ;)
Re: AirOS 5.2 - Firmware Officially Released!!!
Messaggiodi blackthunder70 » 26 agosto 2010, 9:49
Salve, son novo del forum ... e anche nell'utilizzo di 2 Nanostation M5 sulle quali ho installato l'utima release 5.2.
Problema : da qualche giorno NON permette più di salvare le modifiche !!!!
Ho fatto prove sia sulla master (impostata come AP-WDS) che sulla slave (impostata come STA-WDS) entrambe in bridge ed entrambe sulla stessa lan (192.168.1.x e 192.168.1.y) in diverse schermate ad esempio impostando un ip per il watchdog e selezionando la relativa checkbox : clicco su "change", poi su "apply", si riavvia... ma NESSUN cambiamento - la riga rimane vuata ed il checkbox disabilitato!
Vi è già capitato?
Avete per caso trovato soluzione?
Grazie a quanti mi risponderanno...
blackthunder70
Messaggiodi elettrovox » 26 agosto 2010, 17:04
ciao ai messo il 5.2 per le m5?
scarica questo relase beta4 http://www.ubnt.com/downloads/XN-fw-...00818.1847.bin
gia' testato funziona.ok ciao
Messaggiodi blackthunder70 » 26 agosto 2010, 17:16
Ciao!
Ti ringrazio per il link... ma PRIMA di installar su una beta, vorrei capire se quacluno ha riscontrato lo stesso mio problema con la versione 5.2 Build 5132 .
Se qualcuno che ha le stesse nanostatio con la stessa versione di AirOs potesse far delle prove gliene sarei grato.
blackthunder70
Messaggiodi elettrovox » 26 agosto 2010, 18:44
ciao sinceramente a me non mi è successo,ma ad un mio amico si abbiamo cambiato il firmware ed andato tutto ok.
la versione beta funziona perfettamente tranquillo.ciao+
Messaggiodi blackthunder70 » 8 settembre 2010, 16:58
Eccomi qui di nuovo.
Premetto che NON HO ANCORA provato ad installare la beta consigliatami ma nel frattempo ho resettato le antenne ai valori di fabbrica e poi le ho re-impostate con i valori di esercizio lasciano VOLUTAMENTE qualche flag di minore importanza non settato.
Ho riprovato ad effettuare tali settaggi minori ed ad applicarli (..."change" e poi "apply"...) senza risultato : l'antenna si resetta (anche + lentamente direi...) ma i settaggi NON vengono applicati.
Il sospetto di un bug firmware si 'ingrossa'...
Nessuno che possa fare delle prove?
Non appena possibile proverò ad installare anche la beta, ma non vorrei che ciò mi mandasse fuori assistenza con la Ubiquiti!
blackthunder70
Messaggiodi elettrovox » 8 settembre 2010, 18:42
ciao ascolta cambia il firmware e vedi che gli passa tutto,riguardo alla garanzia non la perdi perche' e il loro firmware rilasciato dalla ubiquiti no di terze parti ok.
Messaggiodi admin » 8 settembre 2010, 18:59
Tranquillo, le beta non sono mai state cosi' catastrofiche...
