Rilasciata ieri la V5.2-RC di AirMAX: che sia la volta buona
Messaggiodi ubnt-community » 13 maggio 2010, 15:18
Di seguito la sintesi dei miglioramenti e subito sotto il link al firmware...
V5.2-RC Changelog:
- Fix: Sometimes Auto ACK values gets too high
- Fix: Max power level for Australia
- GUI fix: Name -> Device Name
- GUI fix: Grammar error in warning message
V5.2-Beta8 Changelog:
- Fix: Speed test + AirMax PtP No Ack combination crashes AP
- Fix: Traffic Shaping is not functional except Soho Router mode
- Fix: Traffic Shaping Burst is for functional
- Fix: WPA security : Sometimes station is disassociated from AP
- Fix: Broadcast traffic is duplicated on AP-WDS
- Fix: NAT protocols state changes when changing security
- Fix: SNMP wrong OID type- Fix: Disallow port range as destination (to private subnet)
- Fix: Station can not connect to AP (MAC Locked) if it was connected to another AP with the same SSID
- Fix: Airmax PTMP ping loss issue after beta6
- Fix: AirMax: PTPNack AMQ/AMC fluctuation
- Fix: TX Power improvement for NanoBridge M5, AirGridM5, LocoM5, Bullet M2, Rocket M2, NanoStationM2, NanoBridge M2)
- Fix: AirMax: PTP and PTMP enhancements (latency)
- GUI: Problems with WPA PSK paraphrase: old value is displayed, new value is not saved
- GUI: Sometime Device name in not reported in Stations list
- GUI: Do not show clients as connected when authentication key is not valid
- GUI: Test mode. Timing is no so precise as stated in the warning message
- GUI: Need correctly display ACK/Distance when AirMax and PtPNoACK mode is enabled
- CCR: Report AirMax priority and AMQ/AMC in Station detail
---> Limitation from HW: MCS13 does not work with WEP/WPA/WPA2/WPA-TKIP/WPA2-TKIP security -- MCS 13 removed from WEB UI
V5.2-Beta7:
- Improvement: Power control fix
- Improvement: AirMax: PTP and PTMP latency improvements
- Improvement: Speed test - resolves TX/RX difference
- Fix: SNMP reports incorrect wireless stats
- CCR: Speed test: Show total throughput (RX + TX)
- CCR: Make IP address in stations list as hyperlink
- CCR: GUI: Show/hide Traffic shaping configuration
- CCR: GUI: Add option to enable/disable NAT modules on router: SIP, PPTP, FTP, RTSP
- Fix: MCS1 is always reported in AP/Station statistics
V5.2 Beta 6
- AirGrid M5 fix (in BETA5)
- Fix: Power control fix
- Fix: Signal reporting
- Fix: Noise floor is too aggressive
- Fix: Auto ACK on AP
- Fix: Antenna gain and cable loss no longer available for NanoStation M2/M5
- AirView fix: Sometimes switching back to normal operating mode is endless
- Fixed: IE8 and WEB UI errors
- Improvement in memory allocation
Here are the fixes for BETA4:
- WEP/WPA-TKIP aggregation for Kite/Kiwi radio chipset -- fixed
- Power control fix -- completed
- AirView mode fixes, including endless process while switching back to normal operating mode
- Ping timeout and connection drop fix
- New: Improve ACL rules management: increase max MAC ACL entry count to 32
AirOS v5.2 planned and implemented features:
- New: Speed test tool
- New: AirView tool (Spectrum Analyzer mode)
- New: Routing scenario: Network mode "Soho Router"
- New: NanoStation M5/M2 Second Ethernet port functionality -- now it is possible to bridge with wireless port
- New: Antenna gain and cable loss fields for compliance
- New: AirMax ON in default configuration
- New: Intelligent GUI improvement
- New: Console agent: Restore active heartbeat connections after firmware upgrade
- New: Report 802.11 information messages into syslog
Improvements/change requests:
- CCR: RADIUS client support in AP mode
- CCR: PEAP/MSCHAPv2 support
- CCR: Add static routes via WEB UI
- CCR: Show Station and AP IP address
- CCR: Hide WPA password with "*"
- CCR: Ability to de-associate station from Station list via WEB UI
- CCR: Add support for SSH authorized keys in configuration file
- CCR: Change apply configuration logic
- CCR: Missing ppp0 interface information on Main page, when PPPoE session is initialized
- CCR: Add System Startup Time/Date field (critical for 802.1x supplicant)
- CCR: Allow ping when device is in TFTP recovery mode
- CCR: Include PPTP/GRE NAT modules
- CCR: Add MAC clone/change option for WAN interface when operating in SOHO router mode
Major Fixes:
- MAJOR: Chain signal mismatch on reported signal strength/ Power control fix for M5 2x2 chain devices
- MAJOR: Improve noise level calculation
- Remove DFS 5250-5350 frequency for US country code (all M series products) , but keep the link alive if DFS frequency was used
- No more trimmed channels on Compliance country code
- Frequency list issue fix for counties :
Uzbekistan
Brazil
Honduras
Peru
Philippines
Russia
South Africa
Sri Lanka
Thailand
AirMAX V5.2-RC
ubnt-community
Staff
