AirOS 5.5.1 released
Messaggiodi admin » 6 agosto 2012, 11:23
The airOS v5.5.1 Service Release has been released!
To download or review the release notes, please visit:
http://downloads.ubnt.com
Release note
AirOS V Firmware Revision History
Supported products
* Bullet M, Titanium
* Rocket M, Titanium
* NanoStation M
* AirGrid M / AirGrid HP M
* NanoBridge M
* PowerBridge M
* PicoStation M
* NanoStation Loco M
* AirRouter
* PowerAP N
* Rocket M365
* Rocket M900
* NanoStation M365
* NanoStation Loco M900
* NanoStation M900
* NanoBridge M365
* NanoBridge M900
* NanoBridge M3
* PowerBridge M10
* NanoStation M6
Version 5.5.1-Service Release (July 26, 2012)
New product support:
- New: Rocket M2 Titanium
- New: Rocket M5 Titanium
- New: NanoStation M6
Regional Updates:
- New: Enable DFS frequencies for US/Puerto Rico/ Canada for NanoStationM5/Loco M5/Rocket M5/Rocket M5 GPS/NanoBridge M5 models
- New: Lock Indonesia country code: once selected at Login page do not allow to change country unless reset to defaults
- Fix: Remove DFS enable/disable option for EU, turn DFS ON after upgrade
- Fix: Regulatory rules update for India 2.4GHz band
- Fix: Move Puerto Rico under US regulatory domain
Fixes:
- Fix: AirMax: When one of the clients reboot all others are disconnected from AP
- Fix: AirMax: Unexpected device reboots on high load/PTMP (possible fix)
- Fix: Traffic shaping ingress rules on LAN port in some cases block Internet traffic
- Fix: Traffic shaping bursting is increased to the maximum allowed value according to configured throughput limits
- Fix: Association to non-broadcasting SSID CISCO AP takes couple minutes
- Fix: Complex AP-repeater setup creates loop in this network
- Fix: Increase Password attribute length to 18 when sending empty password to RADIUS server
- Fix: Auto Channel selection logic improvement
- Fix: DFS: Allow UNII-2 band for Canada w/o unlock key for approved product models
- Fix: Traffic Shaper rules changes during upgrade from v5.3.5
- Fix: PPPoE stops sending PPPoE Discovery packets on time change
- Fix: NBM3/NBM365 should support 2 Ethernet ports but shows only 1.
- Fix: Aggregated transmission problems with some Apple laptops and other devices
- Fix: Clients can't reconnect to AP with WPA2-AES security reason (15)
- Fix: After upgrade from v5.3.5 to v5.5 secondary Ethernet port isn't configured (running default configuration)
- Fix: Stations disassociation because of returned broadcast packets on Ethernet interface
- Fix: Second LAN port MTU max is 2024B not 1614B (affected all M series products)
- Fix: No Internet connection for clients behind device in router mode
- Fix: Access Point ignores Session-Timeout limit received from RADIUS server
- Fix: Reduce false positives and misclassifications of invalid DFS radar events
- Fix: Can't launch Airview when initial window disabled
- Fix: Making changes in Network tab resets MTU to 1500 when Management VLAN is enabled
- Fix: Incorrect ebtables VLAN drop rules
- Fix: Do not allow to upload Configuration file from different Regulatory domain
- Fix: Port Forwarding public port range issue
- Fix: After UNII2 band unlock, any changes made afterwards are lost when the device does get power cycled
- WEB UI: Show DFS status in MAIN page
- WEB UI: airSync: Show correct default slots depending on channel size
- WEB UI: Static route disappears in Router mode
- WEB UI: Option to disable Multicast Enhancement for AP
- WEB UI: Improved IP address validation
- WEB UI: Don't enable "DMZ Management Ports" when DMZ is enabled (Router/SOHO Router)
- WEB UI: Bridge table display problem. Table too big
- WEB UI: Do not show graph for interface when it is not in use
- WEB UI: Don't report TOUGHSwitch/airCam WLAN mode in device discovery results
- WEB UI: Add Turkish language support
- WEB UI: In Simple configuration mode LAN should be BRIDGE0 containing both Ethernet interfaces
- WEB UI: Show the same antenna information in MAIN page as in Wireless settings page drop down
- WEB UI: Site Survey Scan button is disabled under IE browser
- WEB UI: Allow MAC Cloning for BRIDGE interface in Router mode
- WEB UI: Bridge table is not displayed in Main page when there are multiple bridge
Security Improvements:
- WEB UI: Default settings change: Enable HTTPS (port 443) by default
- WEB UI: Removed admin.cgi functionality
- WEB UI: Add option to disable HTTP service
- WEB UI: Add reminder when using default admin user name/ password
Lo staff
Re: AirOS 5.5.1 released
Messaggiodi thema3x » 12 agosto 2012, 15:20
Bene !!!
Una bella cascata di fix ( bug WPA2- AES incluso ) !!!
In settimana lo provo su un link "facile" ... vediamo se questo fw funziona bene !
Vi faccio saxe !
Messaggiodi thema3x » 12 agosto 2012, 16:15
Possibile che non trovo il 5.5.1 sul sito ufficiale :emo_pic_105: ?
Ce il 5.3.5 e il 5.5 :sad:
Thnkxx
M
Messaggiodi redfive » 12 agosto 2012, 16:35
E' stata ritirata per un problemino
v5.5.1 was removed due to some regulatory confusions with European countries.
a breve dovrebbe essere disponibile la 5.5.2 RC2 , .....nel forum ufficiale comunque parlano già di 5.5.2 RC3...Stay tuned !!
Messaggiodi thema3x » 12 agosto 2012, 19:06
EH EH !
OK, grazie.
M
Messaggiodi redfive » 19 agosto 2012, 22:17
Messaggiodi thema3x » 20 agosto 2012, 9:17
Bella :eheh: !!!
