Version 5.3 - Final Release (January 14, 2011)
New product support:
- New: 3G Station product support
- New: NanoBridge M365 support
- New: NanoBridge M900 support
- New: NanoBridge M3 support
New functionality:
- New: AirSelect
- New: VLAN tagging: one VLAN per device
- New: Low TX power mode for Rocket M5/Rocket M2
- New: DFS enabled by default for all 5GHz products
- New: Discovery Tool
- New: Ubiquiti Logo Tab
- New: Remove outside 5745-5825 MHz frequency channels for US country (all M series devices)
- New: NanoStation Loco M900: external and internal antenna support scenario
- New: Ability to enter device location (for AirControl server)
- AirControl agent: Support for GPS location reporting
- AirControl agent: Support for latency reporting
- AirControl agent: Configuration changed indicator
- AirControl agent: Report network adapter status/speed
Improvement/Change requests:
- CCR: Add Auto Frequency functionality (AP/AP WDS mode)
- CCR: Jumbo frames support (maximum allowed MTU is 1518 bytes of data)
- CCR: Remove Device name 14 characters limit
- CCR: Sensitivity threshold settings for wireless clients
- CCR: Add possibility to configure DNS address in DHCP server configuration
- CCR: Port Forwarding should support Source IP/mask criteria
- CCR: Dynamic DNS support
- CCR: Improve Firewall rules with ACCEPT
- CCR: Ability to turn auto discovery off under Ubiquiti logo tab/AirControl
- CCR: Remove Refresh button from Main page as it already have auto refresh function
- CCR: New regulatory rules for Germany (5755-5875MHz frequencies removed)
- CCR: Lock to AP MAC functionality for Station/Station WDS
- CCR: Make all columns in Stations list sortable
- CCR: Report negotiated Ethernet port speed on Main page
- CCR: Singapore frequency range changes (remove outside 5725-5850 MHz frequency channels according Regulatory Rules)
- CCR: Turkey frequency range changes (add 5470-5725 MHz frequency channels according Regulatory Rules)
- Improvement: WPA/WPA2 EAP-TTLS improvements
- Improvement: Connection stability improvement when using WPA/WPA2 security
- Improvement: Wireless driver improvements, when communicating to mobile devices using Power Saving
- Improvement: Functionality set for Indoor products (ability to turn on/off AirMax technology features)
- Improvement: DMZ configuration to allow more control over management ports
Fixes:
- AirMax: PPPoE latency in PtMP network with more than 22 clients connected to AP
- AirMax: ICMP ping doesn't pass wireless link
- AirMax: Big delay when transmitting IGMP packets
- AirMax: TX Data rate gets stuck on 81 Mbps, when using No ACK mode for PtP and 40MHz channel width #1618
- AirMax: Voice quality issues in PtMP network
- Fix: Double Auth/Assoc using WPA/WPA2 security when connecting to the AP
- Fix: STA disassociation during WPA/WPA2 group key exchange (affects AES and TKIP security)
- Fix: No connection or persistent station disassociation when at least one station is connected with low RSSI
- Fix: Enabling Client isolation inflicts AP WDS (repeaters) to stop talk with neighborhood AP WDS
- Fix: Intel clients are de-authenticated during rekeying
- Fix: Stability improvements when more than 8 clients connected and some of them are using power save mode
- Fix: Improved power saving handling (Nokia, HTC phones)
- Fix: PS Poll problems
- Fix: MAC changing doesn't work in AP (Router/SOHO Router) mode
- Fix: Throughput slowdown for 2.4 GHz Station when to the same AP is connected at least one AP-WDS peer
- Fix: Previously configured default gateway isn't disabled when WAN interface is configured to obtain IP settings from DHCP server (SOHO Router mode)
- Fix: Ukraine is missing in Country Code list
- Fix: Enable obey regulatory rules in default configuration for PowerAP N/AirRouter
- Fix: Sometimes devices behind STA-WDS are not reachable from AP-WDS LAN side
- Fix: Auto IP aliasing doesn't set IP address if DHCP client is enabled
- Fix: In AP Router or SOHO-Router mode LAN interface can't be disabled if DHCP client is running on it
- Fix: Auto IP aliasing duplicates and is incorrect
- Fix: DHCP Fallback IP is not removed after getting IP from DHCP server
- Fix: Improved wireless client roaming between AP-WDS peers
- Fix: Channel list is required on AP/AP-WDS when enabling DFS
- Fix: Multicast traffic doesn't pass PtP link, when client is using IGMPv3 reports
- Fix: Ebtables module should support VLAN criteria
- Fix: Low Data Rates and CCQ value when link is idle
- Fix: After upgrade DHCP server serves LAN IP as DNS server when DNS proxy is disabled
- Fix: NTP client request interval should be tuned for DHCP Client use case
- Fix: Auto ACK miscalculation, when connected to 802.11a/b/g devices operating in HT5/HT10 channel width
- Fix: Auto ACK calculates incorrect value for very short distance
- Fix: PPPoE client hold off time is not correct
- Fix: PPPoE client is not restoring session after wireless link connection loss
- Fix: Send proper disconnect command to PPPoE server when restarting PPPoE session
- Fix: ARPNAT and PPPoE relay issue
- Fix: AirControl agent: Location values are not reported to AirControl Server
- Fix: DFS: AP doesn't restore operation after 30 min silence
- Fix: DFS: Remove Radar detection capability on STA mode when operating up to 200mW EIRP
- GUI fix: Max power of AirGridM2/AirGridM5 products is 20dBm not 19dBm
- GUI fix: Make VLAN network settings in Bridge mode as separate option
- GUI fix: Reset to defaults redirects to incorrect IP address in SOHO Router mode
- GUI fix: Pop-up windows are not closed on "save" action if parent tab is changed #1668
- GUI fix: Reports two LAN ports on Main page for when device has only one
- GUI fix: When DNS proxy is disabled, take DNS from WAN and fill DNS fields for DHCP server automatically
- GUI fix: DHCP client info is not updated after Renew
- GUI fix: Read-only user permission/redirect issue
- GUI fix: In SOHO Router mode throughput graphic for LAN does not include traffic that goes only on WLAN interface
- GUI fix: Change AirMax priority returns incorrect Warning message
- GUI fix: ACK distance reporting issue in Station Details and AP information
- GUI fix: "Source IP/mask" field in port forwarding should allow 18 characters
- GUI fix: FW upgrade "Close Window" button is not functional if Parent Window is closed
- GUI fix: Misbehavior with Obey Regulatory Rules
- GUI fix: Password field and "Show" checkbox wraps
- GUI fix: Add Antenna model selection for NanoBridge M5 (22 dBi antenna (NBM5-22) and 25 dBi antenna (NBM5-25))
- GUI fix: IP aliasing is not correct in SOHO Router mode
- GUI fix: Output Power slider position when min value is selected
Al solito: http://ubnt.com/support/downloads
Saluti,
Lo staff!
