Ubiquiti cambia anche il dominio di riferimento da ubnt.com a ubiquitistore.com
...la dicitura store fa riflettere
.gif)
PowerBrigdeM
Breakthrough Wireless Performance, AirMax & AirControl Support
150+Mbps of real outdoor throughput and up to 20km+ range. PowerBridge M products utilize Ubiquiti's revolutionary AirMax™ TDMA protocol enabling scalable, carrier-class PtMP network performance. Additionally, AirControl™ application allows operators to centrally manage 100's of devices.
AirWire
The Speed, Performance, and Reliability of an ethernet wire... without the wire
AirWire, a versatile Plug n’ Play wireless solution that requires absolutely no drivers or software, you simply plug one end to your Internet and the other to any wired ethernet device. The easy installation and high performance of AirWire makes it the perfect solution for high bandwidth devices such as PS3, Xbox 360, media computers, set-top boxes, HDTVs with an ethernet port, or even just your laptop!
WiFiStation
Maximize your WiFi Range
Introducing WifiStation and WifiStation EXT, powerful and versatile tools that are capable of connecting to WiFi networks 100+ meters away at 150+ Mbps speeds.
PowerAP N
Indoor Ultra-Long Range 802.11n 300Mbps WiFi AP
Introducing PowerAP N, an indoor ultra-long range 802.11n WiFi Access point capable of connecting 100+ meters away at 300+ Mbps speeds.
Saluti,
lo Staff
