Rilasciata la versione AirOS V 5.1.2, versione accettabilmente stabile dopo la prima versione ufficiale 5.0.
UBNT Support download page
ChangeLog completo
Supported products
* Bullet M
* Rocket M
* NanoStation M
* AirGrid M
* NanoBridge M
Di seguito il travagliato changelog dalla 5.0 fino alla 5.1.2
Version 5.1.2 - Service Release (February 9, 2010)
- MAJOR: Fixed ARP broadcast issues in WDS mode
- MAJOR: Added Mikrotik Station WDS support
- MAJOR: Fix to allow VLAN pass through on secondary Ethernet port (NanoStation M)
- AirMax: Fixed AMC calculation when using fixed rate
Version 5.1 - Final Release (January 07, 2010)
- Throughput improvement for AirMax in PtP environment
- Throughput Improvement for AirMax in 2.4 GHz 40 MHz channel width
- Fixed lower throughput issue when using AirMax No ACK mode for PTP in 40 MHz channel width
- Fixed ping latency issue when AirMax is enabled
- Improvements in wireless stability
- New: Show station ACK value in Station list under Monitor section
- New: Added ip_conntrack_sip support
- Fixed UI issue with signal reporting
- Fixed missing channels in Channel scan list (20/40 Mhz auto)
- GUI: Show only 50% as a max AMC value for 1x1 chain devices
- Fixed DNS proxy and DHCP server configuration issue
- Fixed issue in site survey: cannot select AP when scanning in 5/10 MHz channel width mode
- Fixed issue in admin password: cannot login with admin password when symbols ($, \ or ') are used
Version 5.1-RC3 (December 21, 2009)
- New: Auto rates with MAX value setting
- New: AirMax No ACK feature for Point-to-Point links
- MAJOR: Fixed WPA/WPA2 clients connection stability
- MAJOR: Wireless link stability fix when AirMax is OFF
- MAJOR: Memory allocation issue on AP with more than 60 clients
- MAJOR: Performance improvements in 2.4 GHz
- Auto ACK improvements
- Administrator password limit is 8 symbols
- Allow to increase Logout session timeout
- Allow to disable password authentication for SSH
- 5 MHz channel width is back in 2.4GHz mode
- GUI: AirMax made as separate section under Advanced setting menu
- Fixed GUI issue in AP Mode, Connections shows 0 when more then 45 clients are actually connected
- Fixed MAC expiration issue in Bridge-WDS
- Fixed passing VLAN tagged packets with V5.1-Beta
- Fixed CCQ value when no data
- Show B/G/N mixed instead of Ng, A/N mixed instead of Na
- Fixed Signal Level reporting in UI (RSSI chain mismatch)
- Fixed Data rates selection and reporting
- Fixed download backup configuration file or Support info file issue if using IE browser
Version 5.1-beta (November 20, 2009)
- New: 802.11 a/b/g products support
- New: WEP and WPA/WPA2 TKIP security support
- New: Advanced Ethernet settings
- New: Web server change
- New: AirMax 4 level MAC address based priority
- New: AirMax automatic Voice packet recognition and TXQ assignment
- New: AirMax No Ack (PtP Mode only). Can be enabled only in the config file for the AP by setting radio.1.pollingnoack=1
- New: auto ACK implementation
- Added Arpnat support for more than one IP address per single bridged MAC address
- Updated PPPoE version
- Ethernet driver update
- Added hardware watchdog timer
- Fixed stability issue on link when Airmax is disabled
- Fixed PPPoE Stability in 40 MHz channel width (PPPoE session disconnects due to the no response to 5 echo-requests)
- Fixed WPA/WPA2 client connection issue to AP
- Removed US country code DFS frequencies: 5500-5700 GHz
- Separated L2 isolation and multicast traffic
- Fixed issues in PPPoE daemon when compression enabled
- Fixed switch off for Extra reporting (MT discovery protocol)
- Fixed incorrect CDP packet check sum
- No more FTP speed limits per session when AirMax enabled
- Fixed Compliance test country frequency range for 20/40 MHz channel width
- Fixed SNMP OID numbers persistence (SNMP daemon enumerates all interfaces on startup and assigns sequential numbers now)
- Fixed Web UI lock
- Fixed read-only user account
- Improved signal strength value in 40 MHz channel width
- Fixed signal strength per chain handling when station disconnects from AP
- Fixed data rates reporting for 10Mhz channel width for 802.11 a/b/g clients
- Improved Noise Floor reporting
- Improvement in data rate reporting when traffic is inactive
- Added Device Name in Station and AP statistics table
- Fixed ARP table entry reporting if it contains unresolved MAC address
Version 5.0.2 - SERVICE release (October 23, 2009)
- Fixed Chain 1 association problem in 802.11a mode
- Fixed Compliance test channels in 5 MHz step instead of 20 MHz
- Added VLAN support in Ethernet driver
Version 5.0.2-RC6 (October 17,2009)
- Final Ethernet lockup fix
Version 5.0.5-RC5 (September 26, 2009)
- Uboot fix
Version 5.0.2-RC4 (September 25, 2009)
- Increased Reset to Defaults/Rescue mode timing (triggered from POE and Reset button)
- Added ability to disable reset to default function (from PoE and Reset button) in config
Version 5.0.2-RC3 (September 23, 2009)
- Ethernet lockup fix
- Fixed SNMP agent to report correct values
Version 5.0.2-RC2 (September 18, 2009)
- Fixed web UI slow responses (aka web server loop) on Windows7/IE8 version: 8.0.7057.0
- Fixed PPPoE reconnection issue
- Fixed PPPoE client DNS server issue
- Fixed LAN interface disabling
- Use device name as Web UI Authentication Realm name (allows to use Google Chrome)
- Show FW version on Main page
- PPPoE client can't authenticate if in username symbol # is used
- Fixed connection on low signals: noise immunity is switched off by default. Added ability to change noise immunity on/off in config (not available on UI)
- Fixed AirMax lockup
- DHCP server doesn't work if DNS proxy is disabled
Version 5.0.2-RC1 (August 31, 2009)
- Added Compliance test country code
- Added information text in survey window
- Fixed Memory leak when scanning
- Fixed selected channels scanning
- Fixed WPA/WPA2 association to AP with hidden ESSID on passive scan channels
- Fixed Product Logo displaying if no logo image for device
- Fixed firmware version reporting
- Fixed Rate control algorithm is too aggressive in noisy conditions
- Fixed AirMax AP lock after some time
- Fixed combined signal report in align antenna tool for 2 chains devices
- Fixed hangup issue in router mode with firewall enabled (aka ethernet/iptables fix)
- Fixed scan results for more than 14 stations issue
- Fixed AMC values for 1x1 device should not show more than 50%
- Fixed connected stations reporting for more than 22 stations issue
