AirOS V5.3-Beta2 Released 10/18/2010
Messaggiodi elettrovox » 20 ottobre 2010, 14:23
AirOS V5.3-Beta2 Official change log:
New functionality:
- New: AirSelect
- New: VLAN tagging: One VLAN per device. All traffic going to gateway is tagged
- New: Low TX power mode for Rocket M5/Rocket M2
- New: DFS enabled by default -- change in default configuration for ALL M5 series products
- New: Tool --> Discovery
- New: New Ubiquiti Logo Tab / Settings
- New: Updated US Country Code channel list for compliance
- New: NanoStation Loco M900: external and internal antenna support scenario
- New: Ability to enter device location (for AirControl)
- CCR: Add auto channel functionality on AP (WEB GUI)
- CCR: Implement Jumbo frames support (maximum allowed MTU is 1518 bytes of data)
- CCR: Remove Device name limit (14 char)
- CCR: Sensitivity threshold settings for Client
- CCR: Add DNS fields in DHCP server configuration
- CCR: Port forwarding should support Source IP/mask criteria
- CCR: Dynamic DNS support
- CCR: Improve Firewall rules with ACCEPT
- CCR: Ability to Turn auto discovery off
- CCR: Change Refresh button in MAIN page behavior
- AirControl agent: GPS location
- AirControl agent: Support for latency reporting
- AirControl agent: Configuration changed indicator
- AirControl agent: Report network adapter status
Fixes:
- AirMax: PPPoE latency in PtMP network with more than 22 clients connected to AP
- Major: No connection or persistent station disassociation when at least one station is connected with low RSSI
- Major: STA disassociation during WPA/WPA2 group key exchange (affects AES and TKIP security)
- Major: Device with power safe connection triggers Stuck beacon on M series AP
- Major: Intel clients are de-authenticated during rekeying
- Major: Improved power saving handling (Nokia, HTC phones)
- Fix: Low Data Rates and CCQ value when link is idle
- Fix: Send proper disconnect command to PPPoE server when restarting PPPoE session
- Fix: ARPNAT and PPPoE relay issue
- Fix: Channel list is required on AP/AP-WDS when enabling DFS
- Fix: Previously configured default gateway isn't disabled when WAN interface is configured to obtain IP settings from DHCP server (SoHo Router mode)
- Fix: Singapore frequency change
- Fix: Ukraine is missing in country code list
- Fix: Enable obey regulatory rules in default configuration for PowerAP N/AirRouter
- Fix: PPPoE client holdoff time isn't correct
- Fix: PPPoE client isn't restoring session after lost wireless link connection
- GUI: Max power of AirGridM2/AirGridM5 products is 20dBm not 19dBm
- GUI: VLAN network settings - as separate option
- GUI: Reset to defaults redirects to incorrect IP address
- GUI: Pop-up windows are not closed on "save" action if parent tab is changed
- Enhancement: Functionality set for Indoor products
- Enhancement: DMZ configuration to allow for more control over "management ports"
PLEASE NOTE: THIS IS A BETA FIRMWARE MEANT FOR TESTING PURPOSES ONLY:
Download
