App x Android: AirControl Mobile e EasyUbnt 5.5
Re: App x Android: AirControl Mobile e EasyUbnt 5.5
Messaggiodi ispsoft_1 » 2 settembre 2013, 20:03
New version of EasyUbnt Lite is available to update on Google Play. It's same as the latest full version of EasyUbnt with new UI except several new bugfixes.
Available to install here: https://play.google.com/store/apps/details?id=com.ispsoft.easyubntlite55
ispsoft_1
Messaggiodi nucciopage » 11 dicembre 2013, 18:26
Salve,io ho un problema con aircontrol per android,in pratica mi da questo errore.https://plus.google.com/u/0/photos?pid=5956170320330640818&oid=105997920957794620533
nucciopage
Messaggiodi thema3x » 11 dicembre 2013, 23:18
il link a me non va. Posta la foto perfav !
Messaggiodi nucciopage » 17 dicembre 2013, 22:11
https://imageshack.com/i/f29i18p
nucciopage
Messaggiodi ispsoft_1 » 20 dicembre 2013, 19:36
Hi,
This error means that it's not possible to connect to mentioned webpage of aircontrol server. Please check internet connection of your android device. You should be able to open page http://95.247.103.65:9080 in the android web browser. Try also https://95.247.103.65:9443 for encrypted connection. If it doesn't work it means that your android's network connection is broken, some network firewall is active, aircontrol server is down or you are not using default aircontrol ports. Let me know if you can solve the problem.
Martin
EasyUbnt
ispsoft_1
Messaggiodi ispsoft_1 » 3 febbraio 2014, 23:50
I have some good news! In this week I will release new version 6.1 of EasyUbnt.
EasyUbnt is available on Google Play
Changes will include:
  • New feature - SOHO router mode support
  • New feature - PPPoE support
  • New feature - System log support
  • New feature - Chain0/chain1 signal strength
  • New feature - Localization to czech language
  • New feature - Support for localization to other languages
  • New feature - Possible to load custom configuration file in Configuration screen
  • New feature - Saved devices list is stored on SD card(/EasyUbnt/login.txt) in CSV file format.
  • New feature - Added support for some rare devices (Nanobridge M900, Rocket M900 and
  • Nanostation Loco M900)
  • Fixed - Speedtest bug - login or password with special characters could cause application exit
  • Fixed - Bug in android IP settings change
  • Fixed - Various minor bugs reported by users
System Log
SOHO router and PPPoE support
ispsoft_1
Messaggiodi ispsoft_1 » 5 febbraio 2014, 16:58
New version 6.1 is available now on Google Play.
ispsoft_1
Messaggiodi ispsoft_1 » 17 aprile 2014, 18:46
I would like to announce a new version of EasyUbnt. It fixes mainly problems with beeper on some newer devices. I also tested EasyUbnt with new Android 4.4 Kitkat on Nexus 5 and it works quite fast! If you want to test it, the new version will be available within few hours on Google Play.
Start downloading here:
This is an interesting EasyUbnt Lite country statistics.
ispsoft_1
Messaggiodi drego85 » 18 aprile 2014, 7:26
Good Work ;)
Messaggiodi ispsoft_1 » 29 maggio 2014, 19:14
Updated version released today! It will be available within few hours on Google Play.
Changelog:
* Fixed crashing on connect to some stored devices
* Updated firmware upgrade and firmware download for XW nanobeam firmware
* Fixed DMZ rewriting on config update
ispsoft_1
