PERDITA DI CONNESSIONE CONTINUA
Messaggiodi cristiano555 » 2 settembre 2014, 15:22
Scusate tanto potete aiutarmi, ho una nano tation M2 ma continuamente perde il segnale, vi metto qua sotto cosa riporta sulla MAIN:
potete aiutarmi, grazie.
May 28 17:55:15 system: Start
May 28 17:55:15 syslogd started: BusyBox v1.11.2
May 28 17:55:16 FileSystem: Start check...
May 28 17:55:16 wireless: ath0 Set Mode:Master
May 28 17:55:17 dropbear[917]: Not backgrounding
May 28 17:55:25 wireless: ath0 MLME-AUTH.indication(addr=54:e4:3a:69:f6:06)
May 28 17:55:25 hostapd: ath0: STA 54:e4:3a:69:f6:06 IEEE 802.11: associated
May 28 17:55:25 wireless: ath0 Registered node:54:E4:3A:69:F6:06
May 28 17:55:25 hostapd: ath0: STA 54:e4:3a:69:f6:06 WPA: pairwise key handshake completed (RSN)
May 28 17:55:32 FileSystem: End check.
May 28 17:55:56 wireless: ath0 MLME-AUTH.indication(addr=cc:af:78:c1:8a:e3)
May 28 17:55:56 wireless: ath0 Registered node:CC:AF:78:C1:8A:E3
May 28 17:55:56 hostapd: ath0: STA cc:af:78:c1:8a:e3 IEEE 802.11: associated
May 28 17:55:56 hostapd: ath0: STA cc:af:78:c1:8a:e3 WPA: pairwise key handshake completed (RSN)
May 28 17:59:25 init: reloading /etc/inittab
May 28 17:59:26 system: Stop
May 28 17:59:26 dropbear[917]: premature exit: Terminated by signal
May 28 17:59:26 wireless: ath0 Sending deauth to 54:e4:3a:69:f6:06. Reason: Unspecified (1).
May 28 17:59:26 wireless: ath0 STA-TRAFFIC-STAT mac=54:e4:3a:69:f6:06 rx_packets=146 rx_bytes=9329 tx_packets=36 tx_bytes=6937
May 28 17:59:26 wireless: ath0 Expired node:54:E4:3A:69:F6:06
May 28 17:59:26 wireless: ath0 Sending deauth to cc:af:78:c1:8a:e3. Reason: Unspecified (1).
May 28 17:59:26 wireless: ath0 STA-TRAFFIC-STAT mac=cc:af:78:c1:8a:e3 rx_packets=3194 rx_bytes=557643 tx_packets=3473 tx_bytes=2418047
May 28 17:59:26 wireless: ath0 Expired node:CC:AF:78:C1:8A:E3
May 28 17:59:26 init: process '/sbin/udhcpc -f -i br0 -s /etc/udhcpc/udhcpc -p /var/run/udhcpc.br0.pid -h "NanoStation M2"' (pid 913) exited. Sched
May 28 17:59:26 init: process '/bin/hostapd /etc/aaa1.cfg' (pid 914) exited. Scheduling for restart.
May 28 17:59:26 init: process '/bin/pwdog -d 300 -p 300 -c 3 -m 300 192.168.1.105' (pid 916) exited. Scheduling for restart.
May 28 17:59:26 init: process '/bin/dropbear -F -d /etc/persistent/dropbear_dss_host_key -r /etc/persistent/dropbear_rsa_host_key -p 22 ' (pid 917)
May 28 17:59:27 init: process '/bin/lighttpd -D -f /etc/lighttpd.conf' (pid 915) exited. Scheduling for restart.
May 28 17:59:28 syslogd exiting
May 28 17:59:37 system: Start
May 28 17:59:37 syslogd started: BusyBox v1.11.2
May 28 17:59:37 pwdog[2208]: pwdog: do_now=0, initial_sleep=300, timeout=300, retry_count=3, low_mem=300 exec=`reboot`
May 28 17:59:37 wireless: ath0 Set Mode:Master
May 28 17:59:37 dropbear[2207]: Not backgrounding
May 28 17:59:38 wireless: ath0 MLME-AUTH.indication(addr=cc:af:78:c1:8a:e3)
May 28 17:59:39 hostapd: ath0: STA cc:af:78:c1:8a:e3 IEEE 802.11: associated
May 28 17:59:39 wireless: ath0 Registered node:CC:AF:78:C1:8A:E3
May 28 17:59:39 hostapd: ath0: STA cc:af:78:c1:8a:e3 WPA: pairwise key handshake completed (RSN)
May 28 17:59:44 wireless: ath0 MLME-AUTH.indication(addr=54:e4:3a:69:f6:06)
May 28 17:59:44 wireless: ath0 Registered node:54:E4:3A:69:F6:06
May 28 17:59:44 hostapd: ath0: STA 54:e4:3a:69:f6:06 IEEE 802.11: associated
May 28 17:59:44 hostapd: ath0: STA 54:e4:3a:69:f6:06 WPA: pairwise key handshake completed (RSN)
May 28 18:04:14 init: reloading /etc/inittab
May 28 18:04:14 system: Stop
May 28 18:04:15 dropbear[2207]: premature exit: Terminated by signal
May 28 18:04:15 wireless: ath0 Sending deauth to cc:af:78:c1:8a:e3. Reason: Unspecified (1).
May 28 18:04:15 wireless: ath0 STA-TRAFFIC-STAT mac=cc:af:78:c1:8a:e3 rx_packets=2266 rx_bytes=577629 tx_packets=2047 tx_bytes=1001861
May 28 18:04:15 wireless: ath0 Expired node:CC:AF:78:C1:8A:E3
May 28 18:04:15 wireless: ath0 Sending deauth to 54:e4:3a:69:f6:06. Reason: Unspecified (1).
May 28 18:04:15 wireless: ath0 STA-TRAFFIC-STAT mac=54:e4:3a:69:f6:06 rx_packets=98 rx_bytes=4769 tx_packets=14 tx_bytes=964
May 28 18:04:15 wireless: ath0 Expired node:54:E4:3A:69:F6:06
May 28 18:04:15 init: process '/sbin/udhcpc -f -i br0 -s /etc/udhcpc/udhcpc -p /var/run/udhcpc.br0.pid -h "NanoStation M2"' (pid 2204) exited. Sche
May 28 18:04:15 init: process '/bin/dropbear -F -d /etc/persistent/dropbear_dss_host_key -r /etc/persistent/dropbear_rsa_host_key -p 22 ' (pid 2207
May 28 18:04:15 init: process '/bin/pwdog -d 300 -p 300 -c 3 -m 300 192.168.1.100' (pid 2208) exited. Scheduling for restart.
May 28 18:04:16 init: process '/bin/hostapd /etc/aaa1.cfg' (pid 2205) exited. Scheduling for restart.
May 28 18:04:16 init: process '/bin/lighttpd -D -f /etc/lighttpd.conf' (pid 2206) exited. Scheduling for restart.
May 28 18:04:17 syslogd exiting
May 28 18:04:26 system: Start
May 28 18:04:26 syslogd started: BusyBox v1.11.2
May 28 18:04:26 pwdog[2637]: pwdog: do_now=0, initial_sleep=300, timeout=300, retry_count=3, low_mem=300 exec=`reboot`
May 28 18:04:26 wireless: ath0 Set Mode:Master
May 28 18:04:26 dropbear[2636]: Not backgrounding
May 28 18:05:26 wireless: ath0 MLME-AUTH.indication(addr=cc:af:78:c1:8a:e3)
May 28 18:05:27 wireless: ath0 Registered node:CC:AF:78:C1:8A:E3
May 28 18:05:27 hostapd: ath0: STA cc:af:78:c1:8a:e3 IEEE 802.11: associated
May 28 18:05:27 hostapd: ath0: STA cc:af:78:c1:8a:e3 WPA: pairwise key handshake completed (RSN)
cristiano555
Re: PERDITA DI CONNESSIONE CONTINUA
Messaggiodi thema3x » 3 settembre 2014, 14:00
aggiorna all' ultimo fw. Se ci sei già ri esegui il flash alla stessa versione.
Se non risolve cosi, approfondiamo la casistica con ampia descrizione dello scenario operativo della CPE.
