AirOS 3.6 relased (11/30/2010)
Messaggiodi admin » 2 dicembre 2010, 16:58
AirOS Firmware Revision History
* PowerStation
* LiteStation
* NanoStation
* MiniStation
* WispStation
* NanoStation Loco
* PicoStation
* Bullet
* AP1000
Version 3.6-Final (11/29/2010)
- fix: Source IP/Mask field in Port Forwarding is too short (GUI)
- fix: Check for duplicate IP address, when generating new IP for AutoIP aliasing
Version 3.6-RC (10/05/2010)
- improvement: DFS client
- fix: IGMP proxy is not recognizing upstream
Version 3.6-BETA (09/15/2010)
- new: DFS functionality enhancement
- new: AirControl agent: Support for latency reporting
- new: AirControl agent: Support for GPS location
- new: AirControl agent: Configuration change indication
- new: AirControl agent: Report network adapter status
- fix: Calculated CCQ value is higher than 100%
- fix: Client roaming fails in STA-WDS - AP-WDS configuration
- fix: SNMP: OIDs changes after device reboot
- fix: Port forwarding should support src and dst "ports" criteria
- fix: Uptime in Show AP info is incorrect
- fix: Host name is lost on re-assoc
- fix: Firewall option i disabled without warning if "change" action initiated on "link setup" page
- fix: WEB UI: Read only user can access system files on device
- fix: Add 5470 -5725 MHz frequency range for France
- fix: CDP packet incorrect checksum
- fix: Incorrect Australia output power limits
- fix: Auto ACK doesn't work when WEP security is used
Al solito alla pagin aufficiale di download:
http://ubnt.com/support/downloads
Lo staff ;)
