L'ultima versione ufficiale del firmware AirOS Legacy è la 3.5, rilasciata a ottobre 2009.
UBNT Support download page
ChangeLog completo
Supported products
* PowerStation
* LiteStation
* NanoStation
* MiniStation
* WispStation
* NanoStation Loco
* PicoStation
* Bullet
* AP1000
Numerosi sono i miglioramenti introdotti rispetto alla versione 3.4, i più importanti sono evidenziate in grassetto.
Version 3.5 (10/01/2009)
- increased reset to defaults timings (prevents from accidental reset to defaults).
- fixed: WEB UI lock.
- improved: Traffic shaping.
Version 3.5-rc (09/11/2009)
- fixed: PPPoE client locks up.
- fixed: PPPoE client can't authenticate if in username symbol # is used.
- fixed: Traffic shaping is not working. Can't add shaping rules.
- fixed: VLAN QoS to WMM mapping.
- fixed: Traffic shaper is expected to honor packet priority.
- fixed: WEP entry field validation error message on Web UI.
- fixed: problem with AP channel when in some circumstances(after reboot/softrestart) it might get different from config value
- improvement: STA-Bridge multiple IP and VLAN per MAC.
- improvement: Set pppoe maxfail to 0 by default.
- added: Ethernet port MTU value can be set manually up to 1692 bytes (Long packet support (>1500bytes)).
- added: 152bit (128bit key + 24bit IV) WEP support in Web UI and config.
Saluti,
Lo Staff
