AirOS V3.6-Beta ChangeLog:
- New: DFS functionality enhancement
- New: AirControl agent: Support for latency reporting
- New: AirControl agent: Support for GPS location
- Fix: Calculated CCQ value is higher than 100%
- Fix: Client roaming fails in STA-WDS - AP-WDS configuration
- Fix: SNMP: OIDs changes after device reboot
- Fix: Port forwarding should support src and dst "ports" criteria
- Fix: Uptime in Show AP info is incorrect
- Fix: Host name is lost on re-assoc
- Fix: Firewall option i disabled without warning if "change" action initiated on "link setup" page
- Fix: WEB UI: Read only user can access system files on device
- Fix: Add 5470 -5725 MHz frequency range for France
- Fix: CDP packet incorrect checksum
- Fix: Incorrect Australia output power limits
- Fix: Auto ACK doesn't work when WEP security is used
Qui il link ufficiale dove scaricarlo: AirOS V3.6-Beta - Released 9/17/10
Saluti,
Lo Staff
