posta una foto !
onestamente io non ne ho idea, sarebbe da chiedere a chi ha scritto l' app, magari con una mail.cosi poi posti la risposta
Thanks for the very detailed description. I think I know where is the problem. The app is intended to be used without controller on the network (for example like simple home AP). The controller is very aggressive and if you reset any device previously adopted by controller, it adopts it again after the restart. What is a color of LED indicator on the device? White is unadopted, blue is adopted. Once the device is adopted by the controller, it can't be adopted by the app. We can test it. First remove the device from the controller (click on forget ap button in the controller), it should restart to white LED. Then connect your android to your tplink access point and run UniFi AC app. Does it show your UniFi device now?
We plan to add support for controller in the next release but now the device can be controlled either by controller or by the app.
Let me know if it works.
Thanks for your feedback. This is just a first version of the app. There are many users who like UniFi design and performance but they don't want to run a controller. In next versions we want to connect the app with UniFi controller, it would give app more power and features you want to have.
