redfive ha scritto:La config. non la ho salvata, ho fatto un test una sera, giusto per vedere come andava, ma il problema delle sticky sessions mi ha un pò ...'deluso'....lo avevo segnalato
qui, e il temporaneo workaround proposto è stato quello di farlo funzionare in failover-only.
Comunque ,
qui puoi trovare un'ottima guida.
Cosa sbaglio nella configurazione? non riesco a navigare.
firewall {
all-ping enable
broadcast-ping disable
conntrack-expect-table-size 4096
conntrack-hash-size 4096
conntrack-table-size 32768
conntrack-tcp-loose enable
ipv6-receive-redirects disable
ipv6-src-route disable
ip-src-route disable
log-martians enable
name WAN_IN {
default-action drop
description "packets from Internet to LAN & WLAN"
enable-default-log
rule 1 {
action accept
description "allow established sessions"
log disable
protocol all
state {
established enable
invalid disable
new disable
related enable
rule 2 {
action drop
description "drop invalid state"
log disable
protocol all
state {
established disable
invalid enable
new disable
related disable
name WAN_LOCAL {
default-action drop
description "packets from Internet to the router"
enable-default-log
rule 1 {
action accept
description "allow established session to the router"
log disable
protocol all
state {
established enable
invalid disable
new disable
related enable
rule 2 {
action drop
log enable
protocol all
state {
established disable
invalid enable
new disable
related disable
send-redirects enable
source-validation disable
syn-cookies enable
interfaces {
bridge br0 {
address 192.168.1.1/24
ethernet eth0 {
address dhcp
description WAN
firewall {
in {
name WAN_IN
local {
name WAN_LOCAL
ethernet eth1 {
bridge-group {
bridge br0
description LAN
ethernet eth2 {
bridge-group {
bridge br0
description LAN2
loopback lo {
service {
dhcp-server {
disabled false
shared-network-name LAN-Subnet {
authoritative disable
subnet 192.168.1.0/24 {
default-router 192.168.1.1
dns-server 192.168.1.66
lease 86400
start 192.168.1.100 {
stop 192.168.1.200
dns {
forwarding {
cache-size 150
listen-on br0
gui {
https-port 443
nat {
rule 5000 {
description "masquerade for WAN"
log disable
outbound-interface eth0
type masquerade
ssh {
port 22
protocol-version v2
system {
host-name ubnt
login {
user ubnt {
authentication {
encrypted-password $1$zKNoUbAo$gomzUbYvgyUMcD436Wo66.
level admin
ntp {
server 0.ubnt.pool.ntp.org {
server 1.ubnt.pool.ntp.org {
server 2.ubnt.pool.ntp.org {
server 3.ubnt.pool.ntp.org {
syslog {
global {
facility all {
level notice
facility protocols {
level debug
time-zone America/New_York
/* Warning: Do not remove the following line. */
/* === vyatta-config-version: "config-management@1:dhcp-relay@1:dhcp-server@4:firewall@4:ipsec@3:nat@3:qos@1:quagga@2:system@4:ubnt-pptp@1:vrrp@1:webgui@1:webproxy@1:zone-policy@1" === */
/* Release version: v1.0.2.4507738.121107.1250 */
