XM-v5.5.8.build20991.bin problema
Messaggiodi nucciopage » 22 maggio 2014, 23:38
Salve,ho visto che hanno fatto una nuova build del firmware 5.5.8,lo aggiornata in una nanostation loco m2 e si disconneteva in continuazione.Mentre la vecchia build 207... funziona eggregiamnete.Sapete dirmi qualcosa a riguardo? Grazie.
nucciopage
Re: XM-v5.5.8.build20991.bin problema
Messaggiodi nucciopage » 24 maggio 2014, 18:08
Qualcuno sa dove reperire la versione 5.5.8 build 207? grazie
nucciopage
Messaggiodi thema3x » 26 maggio 2014, 19:47
nelle release note non ce nulla:
AirOS V Firmware Revision History
Supported products
* Bullet M2/M5/Titanium
* Rocket M2/M2 Titanium/M3/M365/M900/M5/M5 GPS/M5 Titanium/M6
* NanoStation M2/M3/M365/M5/M6
* NanoStation Loco M2/M900/M5
* NanoBridge M2/M3/M365/M900/M5
* AirGrid M2/M5/HP/HP New
* PowerBridge M3/M365/M5/M10
* PicoStation M2
* AirRouter/HP
* PowerAP N
Version 5.5.8-Service Release (January 23, 2014)
Regulatory updates:
- New: Regulatory changes for Greece
- New: Regulatory changes for Thailand
- New: Add Croatia under EU regulatory rules
- New: Split Serbia and Montenegro
- New: Remove Compliance Test mode
- New: Lock selected country for all EU countries/Switzerland. Reset to factory defaults is required to order to change country
- New: Available frequency list is updated for UK when operating in 30MHz channel width
New:
- New: Remote Provisioning Functionality for AirGateway
Improvements:
- airMax: Rate drops when using narrow channel widths on AP with more than 30 clients
- Ethernet: Ethernet negotiation issues after ESD damage
- NanoBridge M5: Cold temperature issues
Fixes:
- Fix: DFS frequencies are not functional for Canada (Rocket M5 Titanium)
- Fix: Possible fix for unexpected AP reboots
- Fix: Auto IP Address generation for MAC addresses ending with FF:FF and 00:00
- Fix: SSL server accepts weak ciphers
- Fix: SSH server (dropbear) update to version v2013.58
- Fix: Disabling DHCP server leaves dnsmasq running
- WEB UI: Automatic FW download from web site
- WEB UI: Validate location coordinates
- WEB UI: Copyright updates
Onestamente non ne ho idea. con il precedente XM-v5.5.8.build20795 no problem.
Qualcuno ha maggiori info ?
Messaggiodi nucciopage » 28 maggio 2014, 9:13
In questi giorni faccio un test con una nanostatio loco m2 e questo firmware. Vi farò sapere se ho lo stesso problema di qualche giorno fa cin il cliente.
nucciopage
Messaggiodi thema3x » 29 maggio 2014, 0:17
:okok:
