Ecco una prima lista dei nuovi rivuoluzionari dispositivi mFi!
Link rapidi pagine ufficiali Ubnt-Italia:
mPort mPort pagina ufficiale
mPower mPower pagina ufficiale
Descrizione in inglese:
-mPort devices-
IP Gateway Device for mFi Networks
They supports up to 3 sensors that can be easily attached through standard Cat5 Ethernet cable.
The mPort features built-in Wi-Fi and Ethernet to attach the sensors to the IP network.
Once connected, the mFi controller software enables complete control over all connected sensors.
mPort Serial
mPort Serial features RS232 serial connectivity through a standard DB9 serial port.
Once a machine is connected through the serial interface, the mPort Serial can attach to the IP network using built-in Wi-Fi or Ethernet.
From there, a terminal screen can be launched through the mFi controller software to control the connected machine.
The mPort Serial also features an external antenna connector to support longer range industrial applications.
-mSensors devices-
Wall Mount Motion Sensor - mFi-MSW
Wall Mount Motion Sensor is a dual-technology motion sensor, using both passive infrared and microwave motion sensors to minimize the likelihood of false detections.It is wall-mountable and designed for security, occupancy detection, resource scheduling, and other smart building applications.
For use with mFi mPort hardware and mFi Controller software (included with the mFi mPort).
Connection Type: mFi RJ45
Sensors: Dual Technologies – Passive Infrared and Microwave
Ceiling Mount Motion Sensor - mFi-MSC
Ceiling Mount Motion Sensor is a dual-technology motion sensor, using both passive infrared and microwave motion sensors to minimize the likelihood of false detections. It is wall-mountable and designed for security, occupancy detection, resource scheduling, and other smart building applications.
Temperature Sensor - mFi-THS
Temperature Sensor is a wall-mountable sensor.
It is designed for HVAC monitoring, climate data acquisition, and other smart building applications.
Temperature Range: -10~50°C (14~122°F)
Current Sensor - mFi-CS
Current Sensor is a clip-on, alternating current (AC) sensor. It is designed for current monitoring of motors, lighting equipment, industrial hardware, or other AC electrical loads.
Input Current: 0-100A
Door Sensor - mFi-DS
Door Sensor is a magnetic switch sensor. It is designed to detect open entry points, such as doors, windows, or other physical enclosures.
Connection Type: mFi Terminal Block
Sensor: Magnetic
-mPower devices-
mPower Pro
mFi Power Strip with Ethernet and
Wi-Fi Connectivity
Up to 8 independent switchable AC ports.
Per port power sensing.
mFi Power Strip with Wi-Fi Connectivity
3 independent switchable AC ports.
mPower Mini
mFi Power Adapter with Wi-Fi Connectivity
Independent switchable AC port.
Lo staff!
