Rilasciato Firmware Beta UniFi 3.1.6
Messaggiodi drego85 » 23 ottobre 2013, 21:59
Chagelog
From 3.1.5->3.1.6
Controller - in Performance View, instead of showing "Num Clients" again, show 2G Clients and 5G clients.
Controller - fix the issue of Nokia Lumia 920 cannot connect to ZH wlan.
Controller - add the missing name/address fields for Stripe.
Controller - fix map upload problem.
Controller - fix the issue of deleting “” user from a user group.
AP - support non-ASCII SSID.
AP - disable randomize-case in DNS lookup for compatibility.
UAP-AC - add broadcast/multicast bypass filter for ARP and DHCP packets.
UAP-AC - AMPDU stability improvement.
Download: http://community.ubnt.com/t5/UniFi-Upda ... a-p/600307
