di MikeRoss » 10 agosto 2018, 13:11
il comando:
ebtables -n nat -L
non funziona questi sono i comandi e le opzioni:
ebtables v2.0.10-4 (December 2011)
Usage:
ebtables -[ADI] chain rule-specification [options]
ebtables -P chain target
ebtables -[LFZ] [chain]
ebtables -[NX] [chain]
ebtables -E old-chain-name new-chain-name
Commands:
--append -A chain : append to chain
--delete -D chain : delete matching rule from chain
--delete -D chain rulenum : delete rule at position rulenum from chain
--change-counters -C chain
[rulenum] pcnt bcnt : change counters of existing rule
--insert -I chain rulenum : insert rule at position rulenum in chain
--list -L [chain] : list the rules in a chain or in all chains
--flush -F [chain] : delete all rules in chain or in all chains
--init-table : replace the kernel table with the initial table
--zero -Z [chain] : put counters on zero in chain or in all chains
--policy -P chain target : change policy on chain to target
--new-chain -N chain : create a user defined chain
--rename-chain -E old new : rename a chain
--delete-chain -X [chain] : delete a user defined chain
--atomic-commit : update the kernel w/t table contained in <FILE>
--atomic-init : put the initial kernel table into <FILE>
--atomic-save : put the current kernel table into <FILE>
--atomic-file file : set <FILE> to file
Options:
--proto -p [!] proto : protocol hexadecimal, by name or LENGTH
--src -s [!] address[/mask]: source mac address
--dst -d [!] address[/mask]: destination mac address
--in-if -i [!] name[+] : network input interface name
--out-if -o [!] name[+] : network output interface name
--logical-in [!] name[+] : logical bridge input interface name
--logical-out [!] name[+] : logical bridge output interface name
--set-counters -c chain
pcnt bcnt : set the counters of the to be added rule
--modprobe -M program : try to insert modules using this program
--concurrent : use a file lock to support concurrent scripts
--version -V : print package version
