Prodotti Ubiquiti e Openvpn
Tutto sulle reti Wired!
Messaggiodi kidysy » 7 marzo 2016, 19:03
Buona sera signori e signore. :nonono:
Vorrei farvi una domanda semplice semplice ..si fa per dire!
Ho un serverino remoto dove su' c'è ubuntu server con openvpn
Vorrei collegare due lan a questo server remoto..
Lee sedi devono le loro rispettive lan..in quanto ho dei servizzi da condividere con tutti
Posso farlo con prodotti ubiquiti!
Esempio,io mi connnetto ad internet con la mia NanostationM5 collegata al router.....di pincopanco
Dalla stessa NM5 posso creare una vpn verso il server openvpn??
:surprice:
Grazie mille
kidysy
Re: Prodotti Ubiquiti e Openvpn
Messaggiodi kidysy » 7 marzo 2016, 21:25
Allora,ho fatto un po di ricerche ...
con l'EdgeMax si può fare...
Posto una soluzione copiata dal sito di UBNT.com
Readers will learn how to configure a site-to-site VPN using OpenVPN with two Ubiquiti EdgeRouters.
Assumptions: You want to connect two Edgerouters together using OpenVPN. The two routers are configured as follows.
Router 1:
External IP/Name: system1.dyndns.com (can also use an external IP address)
Internal IP: 192.168.1.1
Router 2:
External IP/Name: system2.dyndns.com (can also use an external IP address)
Internal IP: 192.168.2.1
If your routers use different IPs or you have different names, change them where they appear in these instructions.
Steps
Step 1: On Router 1, access the command line and create a pre-shared key (NOT in Configure mode, but in Operational Mode).
generate vpn openvpn-key /config/auth/secret
Step 2: Transfer the pre-shared key to the other machine
Either:
Option A. This option assumes that the username of the remote system is still ubnt. If you changed the default username, change ubnt in the following command to that new username. This also assumes that the remote machine can accept remote ssh connections, i.e. that port 22 (SSH/SCP) is accepting input from the internet. If the remote system is not accepting SSH/SCP commands from the
internet, use option B:
sudo scp /config/auth/secret ubnt@system2.dyndns.com:/config/auth/secret
Or:
Option B: View the pre-shared key on Router 1:
sudo cat /config/auth/secret
Copy the contents onto your clipboard.
Login to Router 2 using ssh. Create the file:
cat > /config/auth/secret
Paste the text from your clipboard.
Hit CTRL-D to save the file.
Change permissions on the file you just created:
chmod 600 /config/auth/secret
Step 3: Configure Router 1
# Enter configuration mode
configure
# Configure the OpenVPN to use vtun0
set interfaces openvpn vtun0
set interfaces openvpn vtun0 mode site-to-site
# Assign ports for use by OpenVPN
set interfaces openvpn vtun0 local-port 1194
set interfaces openvpn vtun0 remote-port 1194
# Assign a local address for use by OpenVPN
set interfaces openvpn vtun0 local-address 10.99.99.1
# Assign a remote address for use by OpenVPN
set interfaces openvpn vtun0 remote-address 10.99.99.2
# Tell OpenVPN the public address of the remote system
set interfaces openvpn vtun0 remote-host system2.dyndns.com
# Tell OpenVPN where to find the secret file
set interfaces openvpn vtun0 shared-secret-key-file /config/auth/secret
# Enable Compression (optional: Must do on both sides or neither)
set interfaces openvpn vtun0 openvpn-option "--comp-lzo"
# Enable Float, Ping, and Other Security Options (optional: See OpenVPN Man Page for details)
set interfaces openvpn vtun0 openvpn-option "--float"
set interfaces openvpn vtun0 openvpn-option "--ping 10"
set interfaces openvpn vtun0 openvpn-option "--ping-restart 20"
set interfaces openvpn vtun0 openvpn-option "--ping-timer-rem"
set interfaces openvpn vtun0 openvpn-option "--persist-tun"
set interfaces openvpn vtun0 openvpn-option "--persist-key"
set interfaces openvpn vtun0 openvpn-option "--user nobody"
set interfaces openvpn vtun0 openvpn-option "--group nogroup"
# Tell EdgeRouter the remote subnet
set protocols static interface-route 192.168.2.0/24 next-hop-interface vtun0
# Commit, Save, and Exit Configuration Mode
commit
save
exit
Step 4: Configure Router 2
configure
set interfaces openvpn vtun0 local-address 10.99.99.2
set interfaces openvpn vtun0 remote-address 10.99.99.1
set interfaces openvpn vtun0 remote-host system1.dyndns.com
# Tell Edgerouter the remote subnet
set protocols static interface-route 192.168.1.0/24 next-hop-interface vtun0
commit
save
exit
You should be done!
Extra Commands
You can use these extra command line options after the tunnel is created.
Check on the status of the tunnel
show interfaces openvpn
show interfaces openvpn detail
show openvpn status site-to-site
Restart the tunnel
reset openvpn interface vtun0
Notes: The remote-address and local-address are unique addresses used by OpenVPN. They should not be part of the local subnet of either machine.
To set-up a tunnel between Router 1 and a third Router (Router 3), change vtun0 to vtun1. Change the local and remote port to another port (such as 1195). Change local-address and remote-address to something else (i.e., 10.99.99.3 and 10.99.99.4).
kidysy
Messaggiodi kidysy » 7 marzo 2016, 21:57
La questione è interessante ma:
Io non devo connettere due edgemax tra di loro ma devo passare per un server esterno :zip:
Quindi dovrò dire al serverino openvpn quali lan si connettono!
Sono in alto mare!!! Help :surprice: :surprice:
Red... gettami una corda...ma non al collo :o
kidysy
Messaggiodi thema3x » 9 marzo 2016, 20:54
ah ah ah, bella la corda al collo, ci piace :brav:
Messaggiodi redfive » 10 marzo 2016, 14:01
Ti servono comunque due dispositivi che agiscano come vpn client per connetersi al vpn server ed eventualmente far passare il traffico da lui, ma a sto punto ..... non fai prima a prendere 2 ER-X, ed utilizzare direttamente openvpn server/client tra le 2 sedi ?
Messaggiodi thema3x » 12 marzo 2016, 0:11
I :love1: cloud concept... zero VPN ... pochi NAT ... :aureola: i dispositivi client remoti puntano alla farm, attrezzata per erogare tutti i servizi necessari a chi li chiede dietro a "1" NAT.
Messaggiodi kidysy » 23 marzo 2016, 22:54
Salve..! perdonate la risposta ..lungaaaa!!(Nel tempo)
In realtà la questione è più complessa ...in quanto le due sedi sono connesse alla rete tramite due Router LTE ...e come ben sapete ormai le comp..telefoniche hanno messo tutti dietro NAT !!!
Unica soluzione è quella di passare tramite una VPS che funge da server vpn e due client (vpn) con cui posso raggiungere i servizzi nelle rispettive reti!!
Giustamente Red..individua la problematica di avere due apparati per instradare il traffico (VPN) verso il server che dovrà instradare il traffico verso le due sedi!!
Come si dice?? ci sto sbattendo il muso!! :) :)
kidysy
Messaggiodi thema3x » 25 marzo 2016, 12:53
Azzz ... :l0l:
Messaggiodi redfive » 25 marzo 2016, 13:49
Nel mio home-lab, uso 2 connessioni 4G in LB, una è Vodafone, ...va be, questi per avere un pubblico utilizzabile ( perchè danno un pubblico sulla ppp) vogliono il contratto business e si paga il traffico in uscita con b2b ... :oo: , ma la TIM, ho chiesto al 119 di avere un pubblico raggiungibile , e in una settimana tutto è andato a posto (ti richiamano, hanno voluto sapere il motivo, videosorverglianza, anche il modello delle telecamere...), dinamico, ma pubblico ed utilizzabile per connessioni vpn...
Comunque, resta il fatto che ti servono 2 apparecchi che supportino OpenVpn.... gli ER-X, lo fanno egregiamente, sono ultra economici, e puoi configurarli sia come server che come client ( come server lo uso per connessioni H2L, sia da win, che da linux ed android)...
Torna a Wired Network
