salve a tutti...dopo un pò di tempo ritorno con un'altro problemino, ho installato una ns2 e una ns m2...circa 2 km....non proprio in visibilità, ma con un segnale "decente"....solo che la station (ns2) mi salta spesso.....vi posto il log se può essere utile:
Apr 23 15:16:34 CSP 1 user.info syslog: CTRL-EVENT-SCAN-RESULTS
Apr 23 15:16:34 CSP 1 user.info syslog: Associated with dc:9f:db:6e:xxxx
Apr 23 15:16:34 CSP 1 user.info syslog: WPA: Key negotiation completed with dc:9f:db:6e:xxxx [PTK=CCMP GTK=TKIP]
Apr 23 15:16:34 CSP 1 user.info syslog: CTRL-EVENT-CONNECTED - Connection to dc:9f:db:6e:fxxx completed (auth) [id=0 id_str=]
Apr 23 15:22:32 CSP 1 user.info syslog: CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys
Apr 23 15:22:32 CSP 1 user.info syslog: Associated with dc:9f:db:6e:xxxx
Apr 23 15:22:32 CSP 1 user.info syslog: WPA: Key negotiation completed with dc:9f:db:6e:xxxx
[PTK=CCMP GTK=TKIP]
Apr 23 15:22:32 CSP 1 user.info syslog: CTRL-EVENT-CONNECTED - Connection to dc:9f:db:6e:fd:dc completed (reauth) [id=0 id_str=]
Apr 23 15:36:30 CSP 1 syslog.info -- MARK --
Apr 23 15:56:30 CSP 1 syslog.info -- MARK --
Apr 23 16:00:51 CSP 1 user.info syslog: CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys
Apr 23 16:00:51 CSP 1 user.info syslog: Associated with dc:9f:db:6e:xxxx
Apr 23 16:00:52 CSP 1 user.info syslog: WPA: Key negotiation completed with dc:9f:db:6e:xxxx [PTK=CCMP GTK=TKIP]
Apr 23 16:00:52 CSP 1 user.info syslog: CTRL-EVENT-CONNECTED - Connection to dc:9f:db:6e:xxxx completed (reauth) [id=0 id_str=]
